J
Jolle
Hello there. First, I've browsed around this issue for some time now without coming to any closure...
The system is as follows:
ABIT NFS-7 V2.0 Mobo
AMD Athlon XP2500+ @ XP3200+
Radeon 9800pro GFX
512MB Kingston 400Mhz
1 S-ATA 160GB with OS on 20gig of it
1 IDE 80 gig with a 1024MB partition for winxp swap file.
Running Windows XP Pro
Audiophile Delta 24/96 with latest drivers .46
Ok, as many others (it seems) I get crackles and some "pops" when I play sound from the computer. Doesn't matter if it is in winamp or cubase or whatever. I've tried different PCI-slots and making sure I don't get any IRQ-conflicts. Still no good. Haven't found any other drivers than the two you can download from m-audios homepage. Same result with both drivers.
At first I thought the crackling came by random. But I realized that when I had a new started computer and starting a song in winamp I didn't have so much of the crackling. Though when I started working with my web browser and such the crackling got worse. I also noticed that it at times crackled the exact same time as the CPU was working. Like, when the little red LED on the front of the chassi flashed the sound crackled. This is not ALWAYS the case, but very often. It seems anyhow that whenever the CPU does some work the sound crackles exactly the same.
I've tried turning the DMA buffers to 2048 with no result.
I would really appreciate some help. Considering I've got a pretty up to date hardware set up I don't really feel like I should have to strip everything down to sort this problem out. Then I'd rather go over to some sound card that doesn't need dual-CPUs or whatever in order to do music listening and web browsing at the same time...
Radeon 9800pro GFX
