was I brainwashed into preferring the "analog" sound?
  • Thread starter Thread starter CyanJaguar
You cannot compare digital to analog in home studios. Analog in home studios usually sucks. 2k dollars in digital gets you a heck of a nice daw. But you'd have to spend probably 5-10k to get equivalant analog sound out of an analog machine.
The whole process of evaluating the sound of anything (as good or bad, better or worse) is tied into a historical context of what we have come to expect certain things to sound like. There is a certain sound of drums, for instance, that we "like" to hear when we listen to a pop recording. It may only vaguely resemble the drums that we hear at a live concert.
In that context, certain amounts of tape compression and analog distortion have become part of the definition of what we consider to be "good". The problem with digital is that we then have to go spend all kinds of extra bread on plug-ins and outboard gear (like the FATSO) to try to emulate the tape compression and analog distortion, or else it just doesn't sound quite "right". However, the real problem is none of these plug-ins or outboard pieces usually result in a 100% convincing emulation.
The other problem with digital is that you can do it very cheaply and conveniently, but the cheap and convenient systems sometimes introduce other problems that our ears can find unsettling or disturbing. Questionable converters and filters, jitter, rounding errors, poor cabling and connectors, etc. all can have a very unaesthetic effect on the sound.
All that being said, the bright side is the technology keeps getting better and cheaper, plus higher sample and bit rates are also narrowing the gap.
I use digital because of the convenience, editing ability, and economics. But I'm not blind to the fact that it's not quite on a par with top quality analog yet if you are strictly considering sonics.
I bet you that top quality digital is as good or better than most analog though.
I don't understand why the main selling point of old-tech (tub amps, analog recording) is described in the way it often is. after all, how often do you buy a cd because of how 'warm' it sounds?
Depends what you mean by good. There are advantages and disadvantages in each format. And some of the evaluations will always remain subjective.
Also, are you referring to purely the recording format? Or are you including plug-in emulations vs. original hardware processors? Digital vs. Analog mixing boards? Room simulations vs. actual rooms? Etc.
It seems that most mastering engineers prefer the sound of 16 track 2"
running at 30 ips over 24/96 digital. In fact, for many rock type recordings,
even 15 ips analog is preferred also due to the richer low end.
Either format obviously can deliver a top commercial sound, however,
analog still holds the edge IMHO, especially in how it flatters transient
sounds. If you read the articles at the site I gave you, let me know your
thoughts on them!
Chris
