I am considering the feasibility of using USA products in a country where the mains power supply is incompatible (Australia, which has 240V 50/60Hz). Here are my thoughts. Any answers or suggestions would be appreciated.
Replacement Power Supplies Option
For gear which has external power supply plugpacks ("wall warts" I think you call them), I could replace the power supply with a local one that accepts 240V in.
Issues are:
Specific Questions:
Isolated Stepdown Transformer Option
I could introduce a transformer pack that converts my 240V mains into 115V required by the USA wall wart.
Issues are:
I’m not thinking of doing this for all my gear. Just some of the stuff that is hard/impossible to source here and/or is way overpriced.
Regards,
rathpy
Issues are:
- I could stuff up the item if I plug something incompatible in
- Extra cost $10-$25 for external power supply from electronics store
- I could have trouble finding a unit that matches the power output required, eg.15V-500mA. (At least this information can usually be obtained before purchase).
- I could have trouble matching the size of plug that connects into the item being powered. The exact dimensions aren’t usually made available before purchase. General wall wart kits usually have a range of plugs but these might not always fit. I could cut off the plug from the 115V original and fit it to my own, but this would void any warranty.
Specific Questions:
- So long as the voltage is matched does it matter if the wall wart is capable of supplying more Amps than the item requires?
- Is there any way for me to know whether the item requires Regulated power (where the voltage will not increase if less than full current is drawn)?
Issues are:
- More expensive than a replacement wall wart, eg. $65 for 2.2amps.
- So long as the transformer is big enough I could plug a (USA) power board into its output plug to supply several USA wall warts at the same time.
- Electricity wastage higher (how much?)
- Should definitely work for all gear. No fiddly plug sizes or output DC voltages to match up.
- This is a clean solution, Yes?
Regards,
rathpy
