justanotherjo
I don't really know if these are Cubase questions--in fact I know my latency question is not--but I thought I try here first. Also, these questions aren't really about any problems or difficulties, I'm just trying to understand my system a little better.
I'm currently using Cubase SE--hoping to upgrade to Cubase 4 soon. I've been transfering all work I had on my Boss BR-1600 into Cubase--slowly putting the old girl out to pasteur. Most of my projects are currently 8-10 audio tracks with little or no effect processing (yet). I have a few VST/Midi tracks that I am slowly adding.
For all of my projects, the VST Performance bar shows my CPU load at between 3-10%. For most projects, all except for one, in fact, the Hard Disk Transfer Load is very low--consistently less than 5%. For that one, however, the Hard Disk Transfer Load cycles from 0 to to about 20%. There is nothing different about this project and the others--in fact, it only has six audio tracks. This cycling stops if I up my buffer size to 256 from 128. I imported everything into Cubase via the exact same procedure. The only thing I can think of is that this song has a very prominent synth part from a Yamaha Motis ES6--could the difference be a complex audio file from the synth?
Secondly, I am using a M-audio FireWire 410 Audio interface. If I have my buffers set 128 samples, I get a latency of 9.33 ms. If I have my buffers set at 256 samples, I get a latency of 15.88 ms. Is this good, bad, average?
Thanks,
Joe
Thanks,
Joe
