clinton
I'm either mad or both
Hi All
I have posted a similar question in the soundcard section but I think it is probable better here....so sorry for the cross post.
Basically I have my monitors connected to the stereo outputs of my mobile pre and then i use the mobile pre's headphone socket to plug my headphones into when recording with mics... my problem is that every time I record with a mic I have to turn off my active monitors manually each so that they dont play the backing track...
I need to put a volume control between the mobile pre and my monitors.
Now, I have a presonus HP4 headphone distribution amp that has direct monitor outs and a volume pot for that output...if I put that between them I think my problem would be solved..BUT....
How much would that affect the sound coming from my monitors..It surely will affectr it as it is one extra unit in the audio path...do you think its worth it..
Thanks All
Thanks All
