rob aylestone
Moderator
In another topic, we were talking about microphones for voice - as in the spoken word, so voiceovers, narration etc.
As usual we all had some pretty fixed ideas based on how we do things, so I put togeher a test. I took my studio, video and stage mic boxes and picked some old favourites and some totally odd ones. I took a passage from a rather dull manual, and recorded it with 19 different mics.
We had been Using a Zoom H6 in the other topic - which may/may not have great preamps, but concensus was that 50% on the gain knob, pad out wasn't too bad a performance setting.
I recorded each microphone twice - once at 300mm/1 ft, and then again at 50mm/2" so those with pronounced proximity effect would show themselves. I also selected mics that I expected to perform less well, but thought I'd give them a chance. Every phrase was normalised to the same peak volume. On some of the dynamics this meant considerable gain changes, and on the higher output condensers far less. No EQ or other tweaking at all. I've number each one, so I will post the mic 1 = XXX answers in a new post later - that way, you can listen without prejudice. If you listen end to end and look at the mic list - you will no doubt have some good guesses and maybe some surprises. My voice is a constant. If you were recording me - which mic would you pick? I'm hoping some will be dead certs, and others might not be. As I recorded them, some did make me think a little. No clues.
Here is the microphone list - in no order whatsoever.
AKG D112, D190C, 451-CK1, 451-CK8 (short shotgun), 414
Shure SM57, SM58, Beta 58, KSM8, KSM9, SM86, SM63 (omni)
Samson C01
Thomann (chinese sourced) SC-100
Beyer M201
Neumann KMS105
Sennheiser 416 short shotgun, ME-2 (lav)
Audio technica 2020
I'll post the results later on - so my suggestion would be a list with two columns - I'd use these, but not these ...... and then see if any favourites were discounted and odder ones on the possible list.
The recordings
Samson C01
Beyer M201
Neumann KMS105
Audio technica 2020
The recordings
