D
danboy777
I need volume...
Hi, I have spent the last several hours trying to get the scoop by reading between the lines. I have a PC 2.5ghz, 128mb ram with an onboard realtek soundcard. I am recording audio only "spoken word". I have tried both an older ev dynamic mic (no preamp, my mobile dj mic) plugged directly into my soundcard. I have also tried a new sm57 the same way (no pre-amp). The 15 year old EV Mic sounds much brighter, hotter. I am recording in my basement, home office. Here is the problem...
Using sound forge, which I like, I am getting vocals but nothing near the level I need. I have to process it, by amplifying with effects processor on Sound Forge to get them to a decent level. I just feel I shouldn't have to amplify it so much. When I do burn it after processing it at 150% (amplification) it still needs to be jacked way up on volume on the cd player to be heard. This is the part that is unacceptable as these will be sold in stores. Note: I have tried 2 other recording programs but the levels were still an issue.
Please answer:
Would a mic pre-amp solve the problem or would an inexpensive sb live do the trick or both?
I am definitely after quality but my budget is real tight. I'd rather not spend more than another $150.00 total. The idea of a pre-amp is foreign to me because for years (15) I have always just plugged my microphone into my dj mixing board and wham... it worked great. I was unaware that it would need a pre-amp.
Also, would I use SF for my compression or would the mic pre-amp do the job.
Please inform with equipment recommendations.
Whew... thanks!
Please answer:
Whew... thanks!
