I'm trying to mix a song right now. When I mix on speakers, the vocals sound too loud when I play it back on headphones. When I mix it on headphones, they sound too quiet on the speakers. Any tips to minimize the discrepancy?
Also, take your volume knob down to absolute zero with the mix playing. SLOWLY turn it back up little by little... What do you hear first? When I try it with pro mixes, I hear vox and snare, and the click of the kick drum, before guitars or symbols, etc. So, I aim to get a similar situation in my own mixes. This also helps to get those levels right. When the mix is blaring loud, it's hard to judge...
Weird. I get exactly the opposite effect, things panned center (like lead vocals) sound quiet in headphones compared to speakers.
Weird. I get exactly the opposite effect, things panned center (like lead vocals) sound quiet in headphones compared to speakers. You're not putting some sort of stereo widening effect on the vocals, are you?
Sorry, bad wording on my part... What I meant was that I have a tendency to make center items too loud when working with phones.
Aha. In speakers you're hearing both channels with both ears, so things in both speakers (panned center) get an apparent boost compared to things in only one speaker (panned wide).
When listening through monitors, a little bit of what comes out of the Left Monitor also arrives at your right ear, with a very slight delay and vice versa so if you're mixing with phones you're not taking this apparent boost into account and over compensating
Right, but is this not true for headphones too? I mean, there are in fact still 2 speakers in a pair of headphones, no?
There are still two speakers but in headphones the left ear can't hear the right speaker and the right ear can't hear the left speaker.
In headphones if you have a sound in just one side and then add it to the other side at the same level it will just sound like it moves to the center. If you do the same thing while listening on speakers it will sound about 3dB louder, depending on room acoustics. That's why there is a thing called pan law, so that if you pan something the apparent level doesn't change.
