B
bcfromfl
I appreciate the help I've gotten from this board -- thanks to all. I have another question, that I hope is not too difficult to answer given my novice understanding of recording techniques!
I searched this board, and also the web, for processing tips for vocals. I have an excellent mic, running through an Apogee Duet into my Mac with Logic 9. My processing chain is like this: EQ (bass rolled off, slight boost to highs), compressor, limiter, ensemble (turned way, way down), reverb (with wet turned down as well), and a light addition of exciter to add back in a bit of sparkle. The result is good, and very "transparent", but not exactly what I'm looking for.
I read about copying my track (two times, and also four), cutting all frequencies below ~300hz, compressed 20:1, pitch shifting, adding slight delay, panning hard left and right, etc. But when I tried this stuff, it didn't result in what I would call a pleasing effect. I had the copied tracks turned down very low so I could barely hear them, and when I did A->B comparisons, it was so subtle as to not be worth the trouble. Then a louder vocal would come along, and they would become more noticeable with chorused harmonics. Just not what I'm looking for.
I also read that some use doubled vocals...although that this technique sounds like...well...doubled vocals! That's certainly not my goal either.
Below are two YouTube links that represent what I'm looking for. Aside from the obvious skill of Robert Goulet and Brian Stokes Mitchell, what sort of processing do you think is being used here? There is a "smoothing" across transients, and a "richness" that make these recordings a joy to listen to. It's more than just the quality of the microphone, or their training. Am I simply hearing a million-dollar reverb?
Thanks much!
-Bruce
Robert Goulet, "If Ever I Would Leave You" https://www.youtube.com/watch?v=VwfYHVJHMOA
Brian Stokes Mitchell, "Dulcinea" https://www.youtube.com/watch?v=oLsQvCKG58k
Edit: I fixed the links, I hope!
Thanks much!
-Bruce
