T
tbray
looking for suggestions for a vocal mic
Cult_Status02 said:For recording or live purposes?
i agree with everything you just saidguttapercha said:Both. I would wager that more than half of touring acts use 58s for vocals and to go a step beyond that 99% use a 57 on toms or amps. The 57 is the standard for micing guitar cabs and snare/toms - it also is reasonable on vocals.
However, in the studio, vocals are brought-out better with a large diaphragm condenser microphone.
Gear snobs will diss the 57 and 58 sometimes, but if you look at what the pros use, you'll just realize that gear snobs will be gear snobs.
jonnyc said:Actually most of the "snobs" you're refering to would tell you a 57 thru the right preamp is still their choice for snare and guitar cab. Try not to jump to conclusions, there are reasons mic's like the 57 are still around and its mostly because of the "gear snobs" you're refering to.
Try close miking the amp with the 57 off axis...and a good LD 5ft away...only for lead guitar though...do it on all guitar tracks and you will get a ton of mud.thexflamesxburn said:i agree with everything you just said
i tried for the longest time to get a more "expensive" mike than the 57 for recording guitar amps, thinking that there has to be something that can do it better.
Richard Monroe said:Actually, there are a lot of people I wouldn't call mic snobs that don't use the SM57/SM58. Frankly, in the studio roles that many people use a 57 for, I use other cheap mics, particularly AKG D770 and Sennheiser e835. Neither one of those mics is more expensive or any more prestigious than an SM57. And what the hell? I keep an SM57 around because you never know. In the right situation it might be the right mic for the job. However, if you wanted me to mic up a cranked up guitar cab and you handed me an MD421 and an SM57, the SM57 would be put away pretty quickly, in most cases. The SM57 is not a bad mic, and I'm not saying it is. I do believe, however that it is an overated mic.-Richie
tbray said:looking for suggestions for a vocal mic
How much did you want to spend?
