Hard to say. Do you mean for recording a live set or for sound reinforcement?
Normally, when recording, the goal for overheads is to provide an image of the entire kit, to the extent that it is possible to do so, with
the other mics being used to augment the image to the extent necessary. I think I would probably do that even if it's a live set. If I decided the bleed interfered too much with the sound from other instruments and stuff, I could always throw it away during the mixdown, but the goal should be to start out with everything raw so that you have the flexibility to use it or not.
For sound reinforcement, I'm not so sure. Usually I've had to mic everything else so that other instruments can be heard
over the kit. I can't even fathom doing sound work for a gig that's loud enough to need to make a drum kit louder.
Given enough setup time, I think it's probably better to solve bleed problems by better mic placement, to solve
rumble by better mic mounting, and to solve boominess by raising the kit on a platform, moving the kit away from the wall, and raising the mics farther from the floor.
Of course, if there's always time for that, in which case you can always punt my chopping everything out of your overheads but the cymbals and relying on good quality dynamic mics on every piece of the kit. It isn't ideal, but if that's all you have to work with, then that's what you have.
