RWhite, you wanted to know if any hardware manufacturer of audio equipment has posted about VIA chipsets. Digidesign has. I got this info off the compatibility document on the website.
Known Incompatibilities
Caution - Pro Tools LE does NOT support the following systems or systems with the following components:
Hewlett Packard Pavillion line of computers
AMD K6, K6-2 or K6-III processor based computers
Original Pentium processor based computers (Pentium I)
VIA chipset based motherboard computers
Laptop Computers
"ESS Solo-1 PCI AudioDrive" Sound, video and game controller. This device can be disabled from the "Device Manager" in the "System" Control Panel.
VIA Chipset Incompatibility
The VIA chipsets handle IRQ routing and the PCI bus in a way that does not work well with bus master cards. Because Digi 001 is a bus master card we can not support motherboards based on the VIA driver - this incompatibility is consistent with other digital audio cards that are bus masters. To check what kind of bus master driver you have follow these steps:
Right-click the "My Computer" Icon and select "Properties" from the drop-down menu
Select the "Device Manager" tab
Select "Hard Disk Controllers"
The Bus Mastering driver will be listed here
So, there you have it! Digidesign doesn't like VIA either. But I read a post lately that says Digidesign is in the process of 'qualifying' VIA chipsets for use. The fact is that
Asus A7V133, with the VIA KT133A chipset is one of the fast motherboards with the Digi 001 acording to performance test posted on the DUC. I also have a 1.2 Athalon and GA-7DX motherboard which uses the AMD/VIA combo shipset and it works great. With the DDR ram it is even faster than the A7V with the same CPU speed. Digi does not support this chipset either, but I believe they will shortly in the future. The P4 is a very poor performer on performance tests and the PIII is not bad. I love my Athlon. Very fast, very stable.
