sparadiddle
Hi All,
I had been contemplating buying a MR8 (I'm on a tight budget, but who isn't), but after reading the archives in this board as well as the MR8 manual, I decided that I needed a little more, but still something in the budget range. Hence, I'm now considering the VF80.
First things first. I'll mostly be recording solo acoustic guitar (a Martin D-1, nothing fancy), as well as acoustic guitar/pennywhistle and possibly synth. I have almost no gear other than the Martin. I do have a set of Bose stereo speakers and an old stereo amp, and a few Boss guitar effects (including a compressor). I won't be doing any mixing on a PC/Mac (another reason I chose not to get the MR8).
Now on to the questions...
For decent yet inexpensive mics, I've seen mention of both the Studio Projects B1 and the MXL603. As I noted, I'll only be recording acoustic instruments, not vocals. Pros/cons between these two mics? I would like to get two of whichever I end up buying.
I get the impression that the pres on the VF80 or -160 aren't the greatest, but better than what's on the MR8. I see from the archives that the Studio Projects VTB1 is highly recommended. If I buy either a preamp or a mixer (but not both right now), is the preamp the better choice? I don't need to record more than two tracks at once, though something a little better than 2-band EQ would be nice, though not nec.
Compression...how's the compressor on the VF80? Is it worth buying an outboard compressor, or can I get by with the one w/ the VF80 (or the Boss pedal I already own)? I think I read somewhere not to buy the Alesis 3630. Any suggestions?
I don't own any multi-effects, but I'm assuming I can get by with the VF80 built-ins.
All that leaves is some headphones...probably not going to go to expensive on these at first...maybe something like the AKC K-66.
If I can get by without an outboard compressor and preamp with the VF-160, then I may buy that, but if I do need those items, then I'll have to stick with the VF80. Once again, I'll mostly be doing solo acoustic guitar, so I don't nec. need 16 tracks.
Thanks...
Thanks...
