B
blewispunk
I've got a couple questions about using a zip drive to transfer songs from a VF16 to my computer.
First off, which cable do I use? I've seen this question in past threads but I can't find a clear answer. Do I need a male 25 pin for the zip side and a male 50 pin for the VF16 side and if so what is that cable called? The cable I currently have runs from my zip to my printer port.
Also, I usually record 8 tracks and have about 45 minutes of music per session. How many zip disks would it take to do that transfer? Is it even worth considering? I'd rather go with an orb or a Jaz but I already have an old zip drive so I thought this would be my budget solution if possible.
Lastly, I saw somewhere that if you use a parallel zip drive with the vf16 it may damage the vf16... is that true and how do you know if your zip drive is parallel? I'm thinking since my hooks up to my printer port and doesn't require a scsi card that it may be parallel...
Thanks,
Brent
Thanks,
Brent
