<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Cratinus:
the AUX send(s) on the VF16 is/are available via a SINGLE "TRS" phono jack (a "stereo" jack). you will need a handy-dandy "stereo Y-cable" to access the TWO sends on this jack ("tip" for one send and "ring" for the other. i can't remember which is which but there was a small diagram on the back panel NEAR the jack). simply feed the two single ends of the "Y-cable" into EITHER a true stereo processor or TWO SEPERATE effects processors. some effects units can accept a "mono" signal and effect it into a "stereo" signal (via delays and stereo reverb and such). other processors can take two SEPERATE intputs and process each signal SEPERATELY (but simultaneously) and send them BOTH through the L/R outputs of the unit (aka: Lexicon MPX100 and MPX500 among others). with the TRS (tip/ring/sleeve) send(s) on the VF16 you could route (for example) track 7 to AUX1 (and to a delay unit) and track 8 to AUX2 (and to a reverb unit). if you had a STEREO SUBMIX on tracks 7/8 (say a "panned drum submix") you could send track 7 to AUX1 and track 8 to AUX2. route the two ends of the TRS "y-cable" to the L/R inputs of a TRUE STEREO reverb and you can have an "ACCURATELY reverbed" drum submix. IN ALL CASES the effects outputs are routed BACK to the VF16 inputs. I AM ASSUMING (and HOPING,..because i HAVEN'T read the manual) that it IS POSSIBLE to play back 16 RECORDED tracks and STILL HEAR sound-sources that are plugged into the inputs on the top of the unit. if this is NOT POSSIBLE then my theory is hereby "shot to hell" and i resign myself to a public lyching
and subsequent humiliation. i think (or at least HOPE) i'm right, however.
Cheers,
Cratinus<HR></BLOCKQUOTE>
Hi guys. Have
a VF-16 Since last week. Adat input works fine. is fixed to sending on ch 9-16 though. Find good quality.
points that played in favor for selection:
- looked for tool that i could use in stand alone AND with PC-recording (CUbase). I already invested in PC and cards ... . I find that editng is still easier on PC.
In favor:
- It records in WAV ( or rather exports) so you can export it to cubase
- it has ADAT intf, so i can send it to my adat computer card or
my KORG 168RC (digital desk with 8 analog and 16 adat channels) - this means i can use 16 simultaneous analog inputs to record direct to computer OR Fostex. This is a product that can integrate with PC as no other standalone can as far as i'm aware at this price range. Only yamaha AW or Roland 1880 with extra intf card might be able to.
- 16 channel record for a price where others allow 2 to 8 channels
Against:
- effects are for 95% reverb
- track assignment is somewhat hardcoded, unless you ping pong with 8 virtual tracks
- I have the impression that you cannot have 16 recorded channels mix with 8 inputs to create 24 track mix - but need to test this still
- it seems to record 16 bit with 20 and 24 bit convertors -
Korg D16 has 24 bit rec. have no experience to judge the extend of this though and for my ears vf-16 sound brilliant.
- there is no real group/buss system in realtime. the bussrecord seems as a ping-pong record from source to new track whre you can add effects or use it for mixdown. My Korg 168 desk allows to route input tracks to groups and apply effects to the group and then send it to disk-track to record/play all in realtime. Then again i did not find this feature in D16. don't know on VS880 group of products.
What i'm looking for:
- how does mix automation work - where can i find midi info on this - i expect it is too early to expect a VF-16 computer editor based on midi interface.
- how does PC - VF16 hookup work. Disk in VF-16 is in Master mode. This should conflict with computer master disk. Will test it eventually - but might means that direct scsi link to PC is not feasable.
- experiment with buss recording mode. Manual is really unclear. some of the english is uncomprehensable - lucky the project example is clear.
that's it for now great to have found a VF-16 usergroup. Fostex site is none-existing no FAQ, no freeware ...
johan
