jbodner246
ARRR I NEED HELP! I just bought a behringer ultramizer to get good compression/limiting etc. I hooked it up to the aux out jack with a y cable like they say to do. I turned up all the aux levels to max in the vf-16. Now from what i understand this thing should loop thru the compressor/limiter, go back into the vf-16 and then i can master it from there with the effects ( like a loop ) this doesnt seem to be the case. I am also getting no signal on 1 of the channels input meters on the compressor. The compressor has 2 inputs and two outputs, maybe i need a w cable with 4 cables to one? i dont know . please help!
