You simply keep doing an "insert track" until you have 8, then when you arm each track, set the source on each one to the physical input that you want to use on the MOTU. Use the scribble pad on each track to let you know which track gets which mic, then save the whole thing (before you record) as a .veg file so you don't have to repeat the process the next time you want to record drums.
