V67g mods anyone?
  • Thread starter Thread starter usernamebob
Brent Casey said:
Oh I dunno about tossing the entire thing out Tim. There's a lot you can do with that circuit besides changing capacitors and laminations.
Yes but you are not allowed to tell what it is because its secret! ;)
Okay... I emailed cinemag and he sent me back an email regarding what I would need to do
Hey, I recently posted a question on the homerecording.com forums about mods to mxl v67 mics ( http://www.homerecording.com/bbs/showthread.php?t=151857), and was told that I should talk to you about getting replacement transformers. So I was just wondering if you make any aproprately spec'd transformers, and if so what sort of price I would be looking at to get them shipped to Australia, Thanks
Bob
Dear Bob;
Thank you for contacting us about the replacement transformer problem. I took a look at the thread and have these comments:
We do not have the engineering information on the MXL microphones. Thus, we cannot simply give you a CineMag part number for your replacement transformer. These usually have fairly large bodies, so fitting in a transformer should be no problem. From what we have seen inside these microphones in the past, they usually use Chinese transformers. They will have metric sized laminations. This means that you probably will have to make some mechanical modification in order to accommodate something else.
In order to figure out what you need for any replacement transformer, we must start with the turns ratio. You can get this by unloading the secondary and putting a meter across it. Feed a signal of a known amplitude into the primary. The voltage ratio of the unloaded transformer is the turns ratio. Next, determine if it is phantom powered. (Tube microphones mainly are not, but solid state ones often are.) Finally, give us an idea of how much room you have for the replacement transformer. Large usually is good because there is more core and low frequency maximum signal level goes up.
The comments in the thread about the choice of coupling capacitors is accurate. The type of capacitor makes a big difference and is especially so with tube circuits. Higher capacitance also helps by extending the low frequency cutoff and phase shift. However, with high impedance sources you do have to pay attention to the inductance of a wrapped capacitor.
There was some talk in the thread about contacting lamination companies for samples so that you can re-laminate existing transformers. Laminations are annealed. Every high quality transformer company works with its lamination vendors to develop annealing processes to deliver the best characteristics they can. When you ask for a pinch of something you may or may not get professional audio grade laminations. Probably you will not. These high performance annealing processes are proprietary for each transformer company. No lamination company will compromise its OEM relationships to provide samples.
Mention was made of Royer microphone modification kits. They often call for a "direct box" transformer. Dave Royer is a fellow member of the Hollywood Sapphire Group and we know him well. We do have the CM-DBX (which out-performs the Jensen part) for US$45.82. However, we specifically designed a vacuum tube output transformer which is hum-bucking for that purpose. It is the CM-2480. Its turns ratio is intentionally less and gives a "hotter" signal. It sells for $41.63.
We do ship anywhere in the world that has postal service, UPS, Federal Express, etc. Of course shipping, insurance and handling charges depend on the weight, value and method of shipment.
Give me a bit more information on what you are looking for and we will be most happy to help out. Thanks for the inquiry!
Best regards,
David Geren
Vice President
CineMag, Inc.
I have three of the original V67's transformers bare, but don't have the right equipment to test the ratio. I'd be happy to mail them to anyone who can test them so we have a conclusive turns ratio.
Phil,
I see you are in LA. You could just give Dave and Tom a call, ask nicely, stop by their place--if they have time they would be able to take complete measurements of the transformer. Otherwise, if you want, you can send to me and I will measure its ratio and inductance. PM me.
I'll call up Cinemag and see if they'll let me bring them by. Could be good for business if more people have a known part to upgrade.
I can measure the impedance of each winding. Can you get the ratio based on that?
OK, just fired off an email to Dave Geren. We'll see what he says.
No. I suspect you are talking about static resistance. The actual impedance is much more complex and involves resistance, frequency, etc. To measure the voltage ratio you need signal generator and voltmeter. The impedance ratio will be square of the value.
okay, so from looking through here are some posts on another message board... it seems I should do the following..
swap out c2 for a polystyrene of the same value, someone also mentioned swapping out C4 and C8 for panasonic hv's, c6 with a nice film cap and c3 with a .47 metal film or metalized polyester
and then either get a replacement transformer from cinemag if that comes through or relaminate the current transformer.
The other mod I've read about (and done) is to line the inside of the body with leukoplast tape (adhesive bandage) to deaded the reasonance. Are there any other non electrical mods that are worth doing to these mics?
OK, just got a reply from Dave
Dear Phil;
Tom and I are in this business to encourage people to use high
performance pro-audio grade transformers. (If it was just for the
money, we would be doing something else.) Just give us a call and set
up a time to come by. Otherwise, you could send it over via UPS. We
will be happy to characterize the transformers and see if we can solve
the problem.
Best regards,
David
I will set up a time to take it there later this week. Its too far away from me to just rush over unless my schedule changes.
Phil
awesome, it's good to see some good peolpe in this buisiness not just trying to get rich
I am hoping to take the V67 transformer to Cinemag on Friday. I'm very busy tomorrow, don't know if I'll be able to stick around very long. I may just hand it off to them and have them email me the results.
Phil
Getting rich making transformers??? :eek: :eek: :eek:
Maybe they'd make more money if they did the transformers at the top of telephone poles.
Dropped the v67 transformer off at Cinemag. I'll post when I get a response on the ratio.
Flatpicker said:
...The transformer is a 1:2 ratio and I don't know if anyone makes a replacement. Neumann goes straight from the FET into a 1:7 (or maybe higher?) ratio transformer...
Oops! I just noticed that I posted the ratios backwards. Should be 2:1 and 7:1. :o
I think I skipped that post. Did you already test this? Somone owes me $10 in gas! (kidding)
Flatpicker was right. Its a 2:1 and Cinemag does not make a suitable replacement. I checked Jensen's website and they have a couple 1:2's you could probably use backwards. They're over $100 US each, though.
Sorry!
Sorry!
Hi Phil,
Glad you're still at it, I'm in the middle of my last exams ever (bit of an eternal student). Lundahl may be worth a look, maybe the LL1532? Good luck with it anyway :)
Paddy
