Stone B
Thanks, I might stop at Lowes or Home Depot today.
Me myself & him said:Does anyone know exactly (or vaguely) how much more wire (than the lower gauges) is in the higher gauges?
For example, does the 12 gauge wire have twice as much wire in it than the 16 gauge?
Is there a less chance of you blowing your speakers if you use a lower gauge wire?
Me myself & him said:Man! if highschool had been more like this .....
.......................maybe I wouldn't have dropped out![]()
Comparing damping factors is a very amplifier-centric perspective and the importance of speaker wire is vastly overrated when looking at it this way. As a speaker designer I tend to look at it another way:knightfly said:...Let's take our hypothetical 8 ohm speaker, with our hypothetical amplifier at a damping factor of 500 at 8 ohms. From the above math we see that the amp has a source impedance of .016 ohms. If we add the resistance of 16 ga/10 foot speaker wires, we are now at .1158 ohms source impedance. If we now divide 8 ohms by .1158, we just reduced our hypothetical damping factor from 500 to a whopping 69.08 ! This means that, compared to directly hooking the speaker to the amp with zero-resistance leads, we've just cut the damping (speaker control) factor by 7.2 times. Now, let's look at the 12 gauge leads - lead resistance is now .0396 ohms, amp source impedance is unchanged at .016, so the total source impedance is now .0556 ohms. Dividing 8 ohms by .0556, we end up with a damping factor of 143.88 - almost exactly TWICE as good. (more is better)
It's true that clipping is most often the culprit of blown tweeters, but DC current is not the failure mechanism in loudspeakers with passive crossovers. Tweeters are connected via series capacitors, so they never see DC. Tweeters are actually blown because of all the high frequency harmonics generated from the clipping which easily pass through their blocking capacitor. The clipping simply converts low frequency energy into high frequency energy which then fries the tweeters.knightfly said:...Clipping usually takes out tweeters first, because they are not supposed to see any DC current, only high frequency AC. When you clip the waveform into a speaker, there is a period of time during each half-cycle where there is no change in current. This is the same as applying a battery to the tweeter.....
I've designed a bit of everything.knightfly said:Do you design near-fields, or just speakers I wish I could afford, along with the soffited room to put them in?
Bad, bad, bad, bad.What is your take on things like edge diffraction due to un-radiused cabinet edges, non-soffited speakers, near-fields placed too far back on the bridge, console early reflections, etc?...
I wasn't there with test equipment in hand, so I can't say you didn't hear a real difference. All I can say is the placebo effect is very powerful, even if you are consciously saying to yourself "I [don't] EXPECT any difference". I have no doubt that I suffer from it's effect myself. Personally I've spent a lot of time trying to teach myself what various measurable differences sound like, and I always defer to my instruments when in doubt. I'm convinced that there is nothing below the sensitivity of my metrics what has any "dramatic" effect on the sound. And if something like that does arise, I'm pretty sure it will be because I'm just not looking in the right place and need to expand my measurement tools in order to see the effect, rather than it being a case of some mysterious "micro" sonic quality.... why would I have noticed so much change in sound when the only thing I touched was the wires? (Same CD, same level, same positions, same EVERYTHING, just 16 ga to 10 ga wire) Granted, It wasn't a blind test in any way, but before I changed the wires I expected no difference whatever, as I didn't see how .05 ohms or so could possibly be noticed compared to 8. Sooo, if I didn't EXPECT any difference, and your math says I shouldn't have HEARD any difference, WTF? (Highly technical term, means WTF?) Hoping you can 'splain this some more... Steve
knightfly said:generally, get the heaviest ones you can find that will fit your connections, make both channels the same length, don't run them 40 feet if 6 or 10 feet will work, and don't run them parallel to either power or mic level signals.
