Using outboard gear with Aardvark Q10
  • Thread starter Thread starter fatillac
F
fatillac
Hi, I own a pc based recording setup with an aardvark q10 interface and im using sonar xl 2.0. I recently came across a behringer dual 31 band graphic eq and an alesis 3630 compressor. now, my question is..
The Q10 has 4 effects inserts, and 8 outputs on the back.is there anyway i could rig the eq and compressor up so that i could use them on a single track during playback?
ie..
Soloing the bass drum track, compressing it with the alesis compressor and Eqing it in real time?
Is this possible?
Please help
thanks a million!
During playback, I assume you have already recorded the track.
In your software you could assign the track to playback to an individual analog output and run that to the compresor and run the compressor output to the EQ and run that the to an input on the Q10 and rerecord that on to a new track in your multi track software.
larry
