Using Multiple inputs on 2844 NEO
  • Thread starter Thread starter Tunedude
T
Tunedude
Hi- I'm using multiple inputs on my 2488 NEO for the first time. When putting mics into A-B-C and D I can only get two inputs to function at once. A and B will light up, but once I press C-- A and B go off.... What am I doing wrong??? I'm sure you can record more than 2 inputs at once, right? Thanks VERY much for any input. All the best.(Sorry about putting 2844 instead of 2488)
It's working fine. It's only going to light up what you just assigned last. If you press down the INPUT A button, you'll see that the channel you assigned it to lights up also. If all the lights always stayed on, it would be pretty confusing.
thanks RAMI i was confused by the same issue. I thought each track light would be on if it was armed but now get it and yes it would be confusing, just as confusing as the directions which lead you to think every button should light up.
