W
whitey73
I have a Yamaha N12 Desk with only one Auxilery send.
I was wanting to use this to feed monitors for the vocals etc.
I have EZ drummer running in cubase and I want to send ezdrummers signal to a channel (as it alredy is ) and then run this out (by itself) to a powered speaker so only the drums are coming through the 15 inch powered speaker that i have for listening to the drums while playing, trying to save my small but great Yamaha NS10's from a reaming.ie(ABUSE).
Can I use the Insert I/O from the drum tracks channel to send a signal into the speaker. These seem to use a biodirectional TRS connector, but if i use a TRS connector from the Insert I/O on the mixer (tip is hot and sleeve cold ) to a TS connector into the Powered speaker ( tip hot and sleeve cold.)
Would this work .
Any help would be appreciated.
Thanks
Whitey
Would this work .
Thanks
Whitey
