E
esperancia
Umm, hi. I registered here minutes ago-- so if this is the wrong forum for this thread, please do correct me. Thank you!
So I got a problem here.
I have a Samson C01U USB condenser mic.
It appears the mic's sensitivity is now different from when I used it the first time. It's not as sensitive as it used to be.
I realized this via recording volume and also its waveform; it's considerably smaller than how it used to be using the same mic sensitivity level.
I know I've been kinda careless; like leaving the mic when it's not used in random places in my room and not correctly positioning/casing it. Yeah ;_; I'm just a careless amateur home-recording singer. Yeah, or you can change it into 'common careless teenager'.
So.. any idea what's the cause? Is it related to the laptop I'm using? Or just the mic in general? Or other stuff (cable, plug, port, etc.)?
And also.. any idea what should I do about it, to make its sensitivity back to normal? ;_;
I'd appreciate any feedback, and if you need more information about this situation please do specify.
Thank you very much.
