US-122 Problems with Cakewalk
  • Thread starter Thread starter Tommybone82
T
Tommybone82
I too just got the US-122, installed it no problem, but im having the trouble of the clicks and pops, i have no idea what to set my I/O buffers to, how many to enable, and trouble with latency. HELP!! Please
It would help for you to describe your system a bit: what version of Cakewalk are you using, what kind of PC - processor type/speed, OS, memory, etc.
I'm using a US-122 with Sonar3 Studio Edition on a P4 2.8GHz/1 gig PC2700 DDR RAM system and have no problems whatsoever. I've also used it to record on my iBook running OS X 10.3.3 and Audacity, also with no problems.
Another source of info might be to register for and read the User Forums at http://www.cakewalk.com.
I am running an athlon 750mhz, Windows 98se, 256mb ram, plenty of harddive space, unsure of spindle rate. I have the tascam connected directly to the USB Bus, not an adaptor. The only other hardware i have plugged in is my mouse.
No other programs are running except Cakewalk, and the playback and recording is choppy, and the program crashes after using it for a while.
While checking to see if anything else was connected i realized my cable modem-would that have anything to do with it?
You say playback is choppy, too? Are you playing back audio through your computer's soundcard or are you using a softsynth and routing output back through to the Tascam and listening to it through headphones or speakers connected to that?
If you're using your internal soundcard for playback, try disconnecting the Tascam, then playing back audio - any audio, not just stuff you've recorded. If you still have problems with choppy playback, you might want to consider upgrading or at least seriously optimizing your system. Check for extra processes running in the background like antivirus and firewalls, make sure you don't have any spyware going on(use Ad-Aware or Spybot Search & Destroy to get rid of it all!), defrag your hard drive, etc.
If you can play back audio cleanly withouth the Tascam connected but have problems when you plug it in, you've probably got a problem with your USB chipset - it might not be fully compatible with the Tascam unit. See if there are any BIOS updates for your motherboard, although that probably won't help. It might be a better solution to forget about USB interfaces and get a PCI audiocard for recording, like an Audiophile 2496 or something comparable. You'll avoid all the USB-related problems although if you record from a mic you'll have to get something to replace preamp and phantom power supply functions of the Tascam.
