mark4man
MoonMix Studios
OK...
Console View...
Busses...
In SONAR 2.2, I had "Audio & MIDI Modules" on the left, "Auxiliary Busses" in the center; & "V Mains" on the right. I knew what the functionality of each was.
In SONAR4, I have an "Audio & Midi Module Pane" on the left, a "Bus Module Pane" in the center (which contains both Main Busses & Auxiliary Busses) ; & a "Main Out Module Pane" on the right.
Is it as simple as the Bus Module Pane in v4 takes the place of the Auxiliary Busses in v2.2?
I don't think so...because:
In v2.2, the assignment description for the Aux Busses reads:
"Output To: A (ASIO Sound Card 1-2, 3-4, etc.)";
& the assignment description for the V Mains reads:
"Output To: ASIO Sound Card 1-2, 3-4", etc.
The signal flow would then be: Tracks > Aux Bus > V Mains.
In v4, the assignment description for the Main Busses reads:
"Output To: ASIO Sound Card 1-2, 3-4", etc.;
& the description for the Main Outs reads:
"ASIO Sound Card 1-2, 3-4", etc.
It's like they have split up the V Mains.
Right?
Why the split (or is it)?
It looks like the signal flow is now: Tracks > Aux Bus > Main Bus > V Mains (right?)
Wouldn't that add latency?
Thanks,
mark4man
Console View...
Busses...
Right?
Thanks,
mark4man
now why would they do that.
