K
keybuffer
1a. Has anyone tried or considered one of these DMA66-support PCI cards? (I think it's supposed to give you improved throughput to your DMA66 drive if you don't already have full DMA66 support on your motherboard - and most boards out there don't, right? - sort of the UltraDMA equivalent to a SCSI card, I guess. I'm wondering if this should be an inexpensive option for my current set-up. I'm pretty sure my current PCI bus "speed" is 33.
1b. And, with my current set-up (see below), do you think a SCSI card and drive would be a better way to go?
2. In case I decide to build from scratch, I've seen at least one motherboard out there that will run two Celerons (and I think it has a fast bus - it's another ABIT MB). I guess total cost would be a bit more than running one PIII, but if I decide to build from scratch, do you think this be a waste or asking for trouble?
3. Back to an upgrade consideration - my current processor is a regular Pentium 200 (not a socket 1). From what I've seen advertised, there's nothing you can do to improve on it (the processor). Or did I miss something?
My current PC set-up:
Pentium 200 (plain vanilla)
DMA33 PCI bus
No soundcard (less than acceptable on-board Yamaha OPLA SRSG [surround yourself with garbage, and I'm not talking about the band] and I have it disabled in the BIOS - I think it's defective - everyone who's heard and played with the settings say it's defective)
I'm considering the Aardvark Direct Pro.
On-board video
Ethernet card (ISA)
No PCI cards right now - lots of free slots
One 3GB IDE drive, PP Zip, IDE CDRW (slave to HD) & IDE CDROM (master on 2nd IDE)
From this site and a few other sources, I do get the feeling that (for recording) bus "speed" and disk access time are very important things to consider - maybe even more so than processor speed.
Any advice or sharing of experience is greatly appreciated. If number 1 above turns out to be a good option, then I would add a large fast DMA66 drive with card drive to my system (maybe just a 9-gig) for recording rather than building a new system.
DMA33 PCI bus
On-board video
Ethernet card (ISA)
