T
thunderfvck
Hello there!
You may remember me...Well I finally got my computer running, everything works like a gem. I just got the sound card (audiophile 2496) today, and I'm having some problems...
Firstly, I don't have monitors yet. I will buy them in the future, but right now I just can't afford them...So I want to at least have my computer speakers in the computer so I can do SOMETHIGN...But it just won't work! So, I have that little green output for the audio, and I try to put my headphones in there. No sound. I figure the speakers won't work then, since they connect via the same thing.
On the sound card I have L/R audio outputs, looks like I need the fancy monitors to hook up there. How are you able to put headphones through this? Do they have fancy ones with the L/R inputs?
I'm confused. I want to play. I built my computer, put in the sound card and didn't do anything more than insert it into the slot and install the drivers. Could they be clashing with the onboard audio driver thingies, so my headphones in the audio input doesn't work?
Another problem, unrelated...I have two hard drives, 40 GB and 80 GB. The OS is on the 40 GB. The 40 is the master, the 80 is the slave, both are connected to the primary IDE. Computer detects both drives. In BIOS and in windows. But I don't SEE the drive and cannot access it in My Computer. I tried connecting both on cable select, my friend's recommendation, and this didn't work. Any ideas?
Thanks!!
Thanks!!
(which I have!)...
