UA-1G Audio Interface Having a Delay
KlausV
So I'm using the UA-1G with Amplitube X-Gear, and it comes through but always at roughly a half-second delay, no matter what I set the sampling rate or the buffering to. Can anyone help me with this?
More info is needed...
Computer specs?
What other applications (if any) are you running (internet, etc)?
WDM or ASIO or...?
Switch from MME driver mode to ASIO. ASIO is always the lowest latency. You'll need to run ASIO especially if you're using something like Amplitube or you'll never get the latency low enough to echo without a delay.
