Garry Sharp
Lost Cause
I just bought a funky little EQ programme called HarBal (www.har-bal.com) I'm finding it very useful for ear training - learning more about how EQ affects the sound ona stereo mix (before Blue Bear jumps on me, I'm not using the word mastering here, and I see it as a learning tool)
Anyway, the problem I have is that after processing .wav files, it saves them again as .wav files in a format that is either corrupted or unreadable by n-Track or Wavelab. Everything I have (Yammie recorder, PC with Audiowerk 2) is 16 bit. I emailed the HarBal guy with the problem, and received the following reply. I am sure it is 100% correct, but the problem is that I can't understand more than two consecutive words of it. Can anybody help? There are various file type saving options in the programme - I was using the "Windows PCM .wav" one
Reply was:
The problem is that you are using a type 1 floating point format, which due to an internal ambiguity in the LIBSNDFILE library, gets written out as a 32 bit pcm (ie. integer format). Clearly your softwarer does not support this format correctly. The easiest way to avoid this problem is to use either type 3 floating point files or 24 bit PCM (integer) files.
Reply was:
