G
Genie
Hello, I just got the delta44 and am having problems recording at 96kHz. When I record something and play it back, it sounds really slow and distorted. When I record at 44.1 it sounds fine. I've matched the sample rate in cakewalk with that of the delta's control panel config but it still does it. I'm using 24bits at both 44.1 and 96khz, it just seems the 96khz won't record properly. Could it be my computer system.
PIII600
128pc100
7200 western digital hd
Is it even worth it to use 96khz as opposed to using 44.1 when you're using 24bit sound?
Also, is it better to convert down to 16bit@44.1khz for cd burning using something like sound forge to convert(ie: save as: 44.1...) or to change my recording sample rate and record the full mix at 44.1?
Thanks....
p.s. Danzig Rocks
PIII600
128pc100
Thanks....
p.s. Danzig Rocks
