Tube changing help...
  • Thread starter Thread starter PannyDeters
P
PannyDeters
I read on here that putting in a newer quality tube into an ART Tube MP would make it sound better.
So I put in a Groovetubes 12AX7C.
Now, either my Rode NT1 doesn't work, or the phantom power doesn't work.
When I run a battery-powered condensor through the unit, it works. But when I plug in the Rode, it doesn't. I'm not sure if I messed up the phantom power or if the Rode is broken.
Any suggestions?
Also, I put the old tube back in and it still didn't work.
One more thing, what's the difference between a 12AX7C, 12AX7R, etc?
Thanks.
DP
Sounds like a phantom power problem. Hard to say. Check the connectors on the PCB of the ART, maybe you unplugged one of them.
Test your rode through another preamp to eliminate a variable.
Put the old tube back in... if it works, make sure the new tube is a proper 12ax7... if it is, return new tube for exchange.
