You know, I've never really HEARD the difference, but in theory, there are good reasons to use certain cables for things. It is very true that the larger the gauge (smaller numbers) the better the cable is. And this is why: the voltage has less resistance to travel through....think of it as a water hose...if you have a skinny water hose, then the higher you turn on the water, the more pressure is going to build up in the hose, and potentially bust it, with disasterous results...but if you have a thicker, wider hose, then it can handle more water pressure. Now, this is the part where the theory looks great on paper, but I haven't actually heard a difference in this yet. If you use a shorter cable, then the voltage has less distance to travel, so you don't have a potentially degraded signal. I have tried this on several occasions, using a 20 foot cord compared to a 3 foot cord, and I heard no difference...maybe my ears were off....but the theory is correct on paper. It should be the same for anything you use cords to connect, such as your guitar to your amp...and there, the theory would be that wireless would provide the best signal, since you have virtually no cord at all for the voltage to travel through....but if you use a 6 foot cord to play your guitar through your amp, you should, in theory, get a better sound than using a 20 foot cord...so there's something to think about and discuss...just thought I would throw that out there.
