Zona Mona
I was looking at a TS-9 on Ebay and it says it has the following Mods
Thanks
Can anyone tell me if you have these and if they are really as great as the person says?eBay said:JRC4558D Chip Mod
This TS9 has had its stock IC chip upgraded to the JRC4558D chip as found on many of the earliest Tube Screamer pedals.
TS808 Brown Mod
The original tubescreamers were built to overdrive tube amps and the TS9 was changed to better accomodate solid state amps. This TS9 has been restored to the original 808 specs. It also uses carbon composition resistors for a warmer (Brown) overall sound from the pedal.
More/Less Drive Mod
When the Drive control is cranked up there is now more distortion than normally put out by the pedal. When the Drive control is zeroed there is almost no noticible distortion with single notes, and just the sweetest touch of grindy when chording. In between, you get all the classic TubeScreamer tones.
More Bass Mod
The stock TubeScreamer doesn't allow much of your bass signal through the effect. This mod opens the lid on your bass frequencies without sacrificing any of the classic tubescreamer sound. With Drive maxed out you can really tell the difference when comparing a stock TS9 and this modded one.
Thanks
