Troubleshooting a Mackie 1604-VLZ PRO
  • Thread starter Thread starter Cavscoutpao
C
Cavscoutpao
Have had this mixer for several years and it worked fine for live sound. Suddenly I'm getting no signal output from the "Main Out". Plugging the output cables into the 1,2,3 Aux Sends work fine, but that bypasses the entire main mix. Any ideas why this would happen? Nothing has changed in the set up.
I have the exact same mixer. Channel 1 no longer functioning properly. It has sound but lowered and staticky.
Seems like Mackie used to have a good reputation but I've been reading up recently on PA speakers and lots of guys complain about customer support from Mackie.
Sorry I don't know the answer to your question.
(1) On older Mackie VLZ mixers (all I can attest to), the channel fader/slider, if left in one position/setting, would slowly break contact because that spongy/squishsy padding beneath the slider would somehow settle. It drove us crazy for months with tech visits. Move your sliders back to zero when you're done with your sessions. I don't know if this was ever addressed by Mackie---it put us on the Allen-Heath route (absolutely no regrets since).
(2) The internal ribbon connectors are notorious for separating and/or failing in the older VLZ mixers. Not that it happened to all or a lot of them (I don't know), but I'd be willing to bet it's the first thing that the tech is going to suspect. It was the first thing they always brought up to me.
I get the impression that the SRMv2 speakers (the Class-D stuff) is not as well received as the original versions. I did have two SRM150 speakers fail on me---one within an hour (returned & replaced) and the other after about 8 hours (returned). Never got a third one.
Paj
8^)
