Drummerbones
Okay, I've got a Roland TD-3 brain and I bought a full set of the stick-on triggers that go over the rim (I think they're made by Pulse Percussion). I had intended to mic the toms and just blend in the triggered sounds with the live tracks as desired. However, I can't get the triggers to respond correctly. The vibration from the drum head is too inconsistent and I've tried all variations of the sensetivity settings. When I put one of the triggers on a Remo practice pad and whacked it, the response was perfect...not so with the acoustic drum head. Now I'm saying the heck with mixing the tones and considering putting rubber pads on my toms (see the link below) and putting the triggers on them, recording triggered toms only (the reason? just can't get the tom sound I want with this kit or room). Do you think these rubber pads will respond the way I want (like the firmer practice pad did), or will I have to build my own edrum rack out of Remo pads and pvc? Thanks for any advise.
http://www.musiciansfriend.com/srs7/fg=61/g=home/search/detail/base_pid/448318/
