Transporting Projects
  • Thread starter Thread starter blipndub
B
blipndub
Does anyone know how which files I need to work on a project on different machine?
Are all the associated files for a project in one place that I can just copy into the corresponding directory on another machine running the same version of HS2002?
all the audio files you created should be in one folder. probably named "cakewalk" or "something" projects. also, you are going to have to move the wav files folder and the picture cache folder.
do you plan on burning these files to a cd or just going to install another hard drive and send them over that way?
if you are going to burn to cd, i suggest using good cd's. if you use cheap cd's, they WILL become damaged and you will be very unhappy....
blipndub - this is easy. Simply save your project as a bundle file (.bun or .cwb). This will capture everything you need in a single file which you can drop onto a CD.
Just open the bundle file on the other machine and you will be in business. The second machine will, of course, need to have HS2002 installed, as well as copies of any 3rd party plug-ins you are using in the project.
Hey Spacedye, spot on, and they don't come better than Mr. Dachay. He should re-write the bloody Sonar manuals, or at least get some tutorials written:)
