R
RAMI
Guest
Man, I guess I should get real monitors. All I've got to work with is a pair of cheap Hitachi's coming out of my Realistic reciever. I'm scared to hear what my mixes REALLY sound like.
Man, I guess I should get real monitors. All I've got to work with is a pair of cheap Hitachi's coming out of my Realistic reciever. I'm scared to hear what my mixes REALLY sound like.![]()
el oh el
bunch of jokesters around here![]()
...the little cube speaker (forget name - air something)...
The bottom line is that almost everything you hear on todays monitors comes from the little 3/4 to 1 inch dome tweeter. The 5 - 6 inch woofer cut off is something like 150-400 hz or so. The rest 400 to 20K is up to the little tweeter. Made of mylar, or aluminum, I just can't see that this device can be very musical, compared to the 1.5 to 2 inch normal shaped cone speaks found in many computer speakers. So what are you really doing? Trading a 2 inch cone speaker for a 1 inch done squeeker?
If your mixes translate to others systems well, keep it that way, be happy, be really happy and stick with what works for you.
Congratulations man! You are definately changed forever now.
Did you leave your wallet at the store, saves carrying it with you after the endless trips back you will make buying that next piece of gear, chasin that dragon man!
Welcome to the dark side!![]()
broadway panels.
If you provide some way to switch between the speakers you're used to and the new studio monitors you can speed up the adjustment to them. Mix the familiar way with your old speakers and occasionally check the mix on the new ones. Eventually transition to starting the mix on the new speakers and checking on the old ones, then finally wean yourself off the old ones.
Also, listen to a lot of music you like on the new monitors.
You can save some money and get Off-broadway panels.
Back to vaudeville with you, young man!![]()
Oh RAMI, RAMIMammy, my little mammy,
My heartstrings are tangled around Alabammy.
