Transfer Expansion Curves Between Multibands ???
  • Thread starter Thread starter mark4man
:rolleyes:
... This coming from a guy who doesn't even know if we're dealing with compression or expansion.
I give up. You win. As long as you can type more words and further confuse the subject ... you'll always win. If I didn't know any better, I'd think you were the PR guy and not me.
You Chicago guys...:D
Why don't we (by we I mean you) help settle this with an audio sample. In other words what do some of these different settings we're talking about actually SOUND like. Some folks like drum [buss] samples for this kind of thing. Maybe part of a rhythm section would be cool, drums & bass.
Good luck getting Mr. Southside to post anything he's ever worked on.
I still contest the idea that there's expansion happening though, even though the ratio is reversed
Creating a curve in the area below the diagonal input/output line will cause compression. Compression decreases the output level in relation to the input level.
Creating a curve in the area above the diagonal input/output line will cause expansion. Expansion increases the output level in relation to the input level.
What's stumping me is...&...I certainly do not mean to challenge your expertise in any way (as you're already 3, 4 light years ahead of me anyway)...but why would you continue to assume that because the curve has two slopes, one means compression & one means expansion ??? Curves always have (at least) two slopes...that's why we call them curves (?) If the scales were typical; & these curves were of the compression variety...the lower slope would represent I/O below the threshold & the upper slope would represent I/O above the threshold...plain & simple, correct? So why would it be any different in the reverse (characterized as expansion)?
Anyway...I have an e-mail in to tech support at Cube-Tec. If there are any Spectral Design guys still hanging around in the shop...I've asked them to explain exactly what this thing does; & to what extent. I know I said I was giving it up...but you see...I can't...I can't...because, I'm sick...it's PCM sickness, I say....I'm beginning to prefer Nika's book in the evenings over my wife.
[I'm also hoping that this plug (MultiComp); & their Loudness Maximizer, are available as natives for a Wintel system.]
BTW - Meant no offense w/ the South Side origin inquiry. To me, there are three famous South Side locations in America...Chicago, Asbury Park & Boston; & I just forgot to include Boston, that's all.
mark4man
http://www.moonjams.com/musiclinks1.htm
[this of course from the settings in the screenshot]
BTW -If anybody has trouble w/ the .wav's...I'll post streaming .wma's
mark4man
