NashBackslash
Hello, new user here. Nice to meet everyone here.
Anyway, I'd like some advice from all you professionals here on recording nice levels that wouldn't give me much trouble during the mixing stage.
First of all, here is my setup:
Behringer 2442 (using the mixer's built-in pre amps - can't afford external pre amps currently :/) -> direct outs -> MOTU 828 MK2 -> Cakewalk Sonar 3.
I don't monitor from the mixer, that means all the channels on the mixer itself are not routed to any bus (not even main). I monitor from the MOTU, because I want to hear what is actually going into my MOTU.
I feed MOTU's main outputs into channel 16 of the Behringer mixer. This way I can use the fader on the mixer to adjust my volume. Channel 16 is the only channel that is routed to the main bus of the mixer. So in addition to being able to adjust the MOTU volume using channel 16's fader, I also have the main fader on the mixer.
I connect my monitor speakers to the "main out" behind the mixer. I'm using a pair of Alesis M1 active.
Before I start to track, I do the following. What I'd like to know if what I'm doing is correct or not.
I adjust the trim/gain on each of the channels on the mixer to be as loud as possible without clipping the mixer's pre amps. I then adjust the fader. I would monitor the level going into the MOTU (using the MOTU's front display meters) to make sure they don't go above -6 to -4dB. Obviously, this would mean that I am hearing low levels as I monitor the tracks. I end up having to crank up my speakers a bit. Then later during the mixing process, I would turn the speakers down so that I am hearing a "normal" listening level.
Is it normal to do that? Constantly adjusting the speaker levels?
Secondly, the MOTU has options to have the inputs at -4dB or +10dB, as well as a separate +6dB boost on every input. Should I use -4 or +10? Should I use that +6dB boost or stay away from it?
I will appreciate all suggestions and input. Thanks!
- Nash
- Nash
. Specifically it means, for example, on a mixer fader the setting about 3/4 of the way up that is labeled "0", which is the point at which you are neither boosting or cutting the volume.
