P
pewterbird99
I got a UX2 Toneport the other day and figured I would tell you guys what I thought about it. I had looked around a lot before I bought it and noticed there wasn't that much information on here about it. My first thoughts when opening the package was that it seemed a little cheap. It is very light and made completely of plastic. I figured it may be a little more "dense" feeling but it wasn't. After I plugged it in and installed it, I still had a little trouble getting it set up to play sound. I finally figured out that you need to set it up as your default sound card and you also have to pick the source that you are using (in gearbox). After I got everything working though I was very impressed with it. Gearbox has a lot of features to play with like mic placement, pre-amp ect.... The tones for guitar in gearbox do sound a little digital I have to admit, but I did notice that if you multitrack your guitar with differen't amp models it begins to sound pretty decent. This thing will be a dream come true since I live in an apartment with roomates and can't crank my amp up. I have played with Amplitube before but I thought the tones pretty much sucked. Also it's hard for me to get into recording playing a track clean and then swamping it with distortion later. I personally need to hear it all at once. I record with Adobe Audition and the UX2 works fine with it. One problem I did run into though was that I had to make sure that the UX2 and Auditions recording defaults matched i.e.(44100 16 bit) because Adobe will crash until you do. The vocal pre amps in gearbox are cool to. You could play with it for hours just messing with all the different effects. Anyway, I just wanted to give people my two cents in case anyone was thinking about purchasing one. Overall, I thought that the UX2 is a pretty cool piece of equipment and is definately worth the money.
PS. Usb powered devices rock (one less wall plug you have to worry about)
