Silentsound
My intention was to open his options and to show that there are many factors to a clear mix.
Having seen only answers on EQ, I took the issue to another aspect of mixing that would at the very least show other areas to experiment with sound to try to achive his goal EVEN with out hearing the mix itself.
I accept your challenge
![Smilie :) :)](/images/smilies/smile.gif)
and will try to be more explicit and not, how do you say "to easy to quote or understand".
BigBee,
Although Eq is a main factor in making a space for each instrument, stereo imaging has a 3 dimensional perspective that will help a mix sound balanced, open,interesting etc....
Those 3 are low-high, left-right, close-distant.
Left -right is perhaps the simplest of them. With panning you can achive a partial clearing of your mix as well as a good balance between the instruments.
When we move a instrument out of the way not only does he sound more clear but he makes the other parts sound clearer also.
Example- when you pan the keyboard left and the guitar rught you make room for the center parts as well.
I don't like to pan hard left and right as this can sound bad in a mono mix and can also cause a unnatural sound for a typical middle of the road mix. However people like to pan hard for the interesting stereo sound and a very clear mix in Stereo.
When you pan a single instrument to one side you have to be carefull that you don't upset the balance !. A distracting pan can make it sound lopsided.
Close -distant is a commen part of sound we hear.
Using reverb and delay can achive this for you. As you change the level of your part and your wet/dry "%" on your reverb and the predelay, you'll see how the distance changes
Example- play with the predelay and you'll see how the size of the room changes. Play with the levels and the reverb combination of dry/wet;and you'll see the sound
move closer or futher. I suggest you experiment with a big hall and that will make it more clear.
Up -Down can be achived by 2 methods
1. A very short delay to the same panning postion you placed the original part
2. EQ- Low eq's give a lower vertical sound and High's give a higher sound. That is way A Bass part can sound under a vocal although both are panned center.
Widening your stereo image- A stereo reverb can open space
and open a mix.As can a delay from the original part when it's sent to the other side of the panning spectrum.
even better if you Eq each part (original and delay) by boosting one and cutting the other at the same freq.
Combining 2 different revrebs can also add depth to a sound.
Example- try putting a part in a room reverb and then listing to it as you put that room reverb through a hall reverb.
I hope I have made myself clearer and although I can't hear your mix to give you specific advise you can try some of these ideas and maybe it can help you solve some of your problems.
Good Luck
