GONZO-X
http://www.nowhereradio.com/artists/album.php?aid=2302&alid=-1
it's called "Pod-1"
i used nowhere radio, so i could burn a 160 kbps mp3....... sounds a 'little' bit better than standard 128.........
This is my first recording with the new POD XT.
it's not a song, per se....
simply, a means to experiment with the different sounds and effects.
i laid down 4 back to back section "grooves" with the drum machine, then tracked a bass part (through the pod) and 2 to 3 guitar parts (in stereo) to each section....
now of course, this is a 160 kbps mp3, so it's not going to sound as good as a wav off of a cd.....
but it should show some of the POD versatility.....
The drums were recorded dry......
The bass was recorded through the pod using a "tube amp" model, and no speaker model...
basically, a tube direct.....
All guitars were recorded using the same electric, my custom strat hybrid with the seymore duncan lil 59 in the bridge, and the bill lawrence singles in the middle and neck positions......
all effects are directly from the pod. the guitars were all recorded direct and dry, with no eq til mixdown.....
so the idea was, to give a fair approximation of what the guitars sound like coming right off the pod.......
this mix was done to showcase the sounds of the pod....... not to mix a tune....
i'll give more details on the amp models used per track, speaker models per track, microphone models (yes, microphone) per track, effects per track........ later.
it's called "Pod-1"
