J
jtienhaara
SonicAlbert -- this is good, this is the first time I've ever run into somebody who has 1) done this hybrid stuff and 2) is willing to talk about it!
Cheers for that.
Undoubtedly a "to-may-toes" / "to-mah-toes" thing. I had just never come across the expression "double bussing", and was just making sure I understood what you meant.
Not quite so complicated. Just record a sine wave (at e.g. 1000 Hz), then play it back ITB and through each plugin and plugout you'll be using and record each one to its own track, one at a time.
Once you've done that, calculate the difference in time between each new recording and the *slowest* of the plugouts. For each track, that is your latency delay compensation. You can reuse the same latency delay compensation thereafter until the end of time, and it will still sound good!
Incidentally though I don't use very many plugins, so I know mine well and I don't swap them in and out all the time. I find plugins tiresome and draining and anti-creative, so once I've found a good one I stick to it, prec-calculated latency compensation and all.
I don't have the benefit of a UAD-1 (equivalent to a medium priced outboard effects unit in some ways -- even though the compressions is undoubtedly much cooler in the UAD-1 than in most outboard effects units). Also I have a very static setup, one of the niceties of using the DSP-based CreamWare cards.
Nevertheless setting up delay plugins for each mix is nothing compared to moving tracks around to compensate for latency, in my books!
I'm sure you're a far more experienced and accomplished mixer than me, but I have the same goals as you -- simplify, and make it sound natural and better! -- we've just arrived at different conclusions. My mixes take a *lot* of time (chalk that up to lack of experience or what have you). Recall is vital for me and is the reason I moved to ITB. Everything I use now -- analogue compressor settings being pretty much the only exception -- is recallable. This, to me, is *much* more natural than the mixing process I had when I wrote down every bloody EQ, fader, aux, etc setting on my outboard mixer, so that I wouldn't lose my place mixing a song during the interim while I recorded a jam session etc.
But to each his own!
And for what it's worth I would love to have you mix something I've worked on, some day, SonicAlbert. It would be an honour for me. I've never heard your mixes, but I've read your posts and I just know I would like what you do.
Cheers,
Johann
SonicAlbert said:Yes, I mean parallel bussing. Isn't that and the term double bussing pretty much interchangeable?
SonicAlbert said:You have to calculate the latency for the entire signal path to analog, including the interface and any digital mixer and then the DA converters.
SonicAlbert said:Speaking purely for myself, I've found that simplifying the process in certain ways makes it go a lot more naturally and better..... Maybe I'm not just a good enough mixer, which is highly likely.
Cheers,
Johann
