Lt. Bob
Spread the Daf!
no, that's not quite right.That's the center of the speaker? Jeez. How close?
Keep in mind that the center of a speaker is usually the brightest placement, but it also sometimes can sound like what you have here because the center of the speaker doesn't actually make any sound. If you pop the dustcap off a speaker, there's a hole back there. There's nothing there. .
yes, there's a hole back there in most speakers to help airflow around the voice coil to prevent overheating.
But the dustcap is a part of the cone and moves with it.
Since sound is produced by the speaker cone moving back and forth and pushing air .... the dustcap absolutely makes sound and just as much as the cone.
If you took off the dustcap the center wouldn't make sound, but with it in place ...... it's simply a part of the cone.
In fact ... you can alter the sound quite a bit with the material the dustcap is made from.
Speakers with that shiny aluminum dustcap ( like JBLs used to have ) are super bright and spiky.
When I get my JBL D110s reconed I'm gonna make them use paper dustcaps to tame them a bit.
