wheelema
Boner-obo
But that's just because I think homerecording is the most important market in the world and before a recent post I'd never heard of Rane.
My overwhelming focus is on female vocals right now. I've looked at a boat load of preamps and channel strips and then ALONG COMES THE RANE VP12!
Also, note that
So, for $449 smackers, how does it sound?
- Studio grade microphone preamplifier with processing phantom power, input gain, low and high cut filters
- De-esser
- gate/expander and compressor, each with separate threshold
- 2 bands of parametric EQ
'that each band has a frequency multiplier switch that allows the range to cover 10 Hz to 20 kHz. A Bandwidth control allows control over a wide valley or a narrow crevasse. If +12 dB of Boost or -15 dB of Cut isn't enough, the filters are in series -- so simply setting the filters to the same Frequency can double the amount of Boost or Cut'
Also, note that
'Independent Bypass switches in each processing section defeat unnecessary processing and allow process/unprocessed comparisons. Additionally, each section of processing can be re-patched in any order via screw terminal jumpers on the rear of the unit'
