The E-MU Xboard 25
  • Thread starter Thread starter midwest
M
midwest
i just bought The E-MU Xboard 25 and it works well with FL 5 but i cant get tha Proteus X LE Desktop Sound Module to work tha only reason why i bought this midi controller is because they said they have over 1000 sounds i cant load tha Proteus X LE Desktop Sound Module into FL 5
does anyone no how to work tha Proteus X LE Desktop Sound Module ??
error--- the steaming engine cound not be initialized
when i try to load it in FL as a VST
THANXS IN ADVANCE
I recently bought the 49 key version. Same software, Proteus LE and I have been getting the exact same error message.
Anyone know the solution?
Sounds like a software bug/compatabilty problem. Has someone check for a software update?
I found my problem. Running Windows XP and using the Ableton Live software that came bundled with the Xboard. Not sure if this will work for you.
Windows had overwritten the Emu driver for the Xboard with it's own driver. The Proteus X LE that comes with the key controller is protected so the Xboard first has to be always connected and active before you load Proteus as a VST instrument.
Go to Hardware / Device Manager and check to see if the Driver is listed as EMU or a Windows driver. If not EMU, follow the instructions in the manual about installing the correct driver. You'll have to do it manually or Windows uses it's own.
I fixed it up last night and everything is running smoothly.
Yes
The Xbord Must Be On And Active Before Proteus Loads
