The Basics
  • Thread starter Thread starter Mush Witz
M
Mush Witz
Hey,
I'm really new to all this.... n'kind of wanted to satrt a home studio....
so i just wondering if you guys could help me, telling me the basics..... the basic equipiment needed, basic softwares and stuff :)
Thanks ;)
Lots of variations here. What do you want to record in your home studio? What gear do you have today? What level of quality do you want to achieve?
Ed
For computer recording, you need a source > mic > preamp > ad (analogue to digital) converter > interface > computer/software. Once recorded, you need DA convertion > monitors > working ears ;). Everything depends on your budget and what you want from it.
Mics: For full band recording you will need some dynamic and condenser (require a voltage) microphones. People usually use dynamic microphones for close-miking drums, guitar amps, etc. and condensers for drum overheads, acoustic instruments, etc. Vocals are usually recorded with an LDC (large diaphragm condenser).
Preamps: These can be found stand-alone, in a mixing desk or in an interface. This boosts the signal to an acceptable level.
AD/DA conversion: These can be found stand-alone or in an interface. It converts the analogue signal to digital.
Interface: These take the digital signal into and out of the computer. A soundcard is a type of interface.
Software: There are so many options available, as with all the others, so it depends solely on what you need and your budget. Some basic softwares are free (audacity, etc) or come freely with interfaces (cubase le, etc.).
Monitors: You need to be able to listen back to the recording and mix, so you need monitors (speakers/headphones). It's important to have monitors which are as flat (in sound) as possible.
Acoustics: Acoustics are hugely important. If a recording is made in a small room, it will always sound like it's a small room and that is generally not a good thing. Each room has its own "sound" and acts like an EQ on the sound(with different settings for different parts of the room). You can change/influence the sound with acoustic treatment. This includes absorption and diffusion. It's generally a good idea to have a variable recording environment (able to change to suit) and a flat listening/mixing environment. For small rooms/studios absorption is generally recommend, especially bass traps in corners.
What i suggest depends solely on what you need and your budget. If you just need vocal recording, then you can get away with one or two tracks. For small bands recording individual, 8 tracks should be adequate. For a large band, recording simultaneously, more tracks will be required.
I usually, if the budget allows, suggest having more tracks than you think you will require. For vocals, you can usually get away with one, but I'll suggest 2, 4 or even 8 tracks to allow expansion. For a small band, recording individually, you can get away with 4 tracks, but i'd suggest 8+.
So, what is your budget and what do you need?
;p
Thanks guys....
So..I'm really looking for something not really expensive.... just to record my own stuff in a kind of DEMO way....
as far as equipiment, i am pretty much empty.... so i was looking for some basic equipiment to buy...
and as far as softwares.... i've had Sonar, Audacity, and soundforge... but never really recorded anything for real...
so... waht should i do?:rolleyes:
get a lava lamp.
:D
Seriously...do a search here for the goodz that Pandadude was talking about and google Tweakheadz for more beginner ideas. Good stuff at both places.
It's alot of reading but better than blowing your hard earned moola on stuff you'll grow out of in 2 months or other stuff the salesman siad was a "necessary" item.
Luck man.....
Pandamonk has a good reply here.
I always like to refer people to the Tweak Guide because it covers most everything start to finish. You can skip over sections that don't pertain to you.
http://www.tweakheadz.com/guide.htm
I also like the book, Home Recording for Musicians for Dummies by Jeff Strong. You can search for it on Amazon.com
Most audio interfaces will come with a Lite version of a popular DAW (Cubase, Sonar, etc). Look for that when your shopping around for interfaces.
Have fun,
yeah
okay...
thank you guys....
so i'l take a look around those things you guys said ;)
Thanks a lot :D
Ps: i really liked your sound Chili ;)
Thanks guys....
So how many tracks do you need and how much are you willing to spend(maybe convert to $ or £s).
Hmm... as far as money... i don't have a clear idea of how much i want to spend... i mean... just to record my own stuff... maybe, somewaht close to $500 ???(really just to record own stuff)
i really don't know... hehehehe:(
And as far tracks.... basically 4 tracks... or 5...
:P :)
Hmm... as far as money... i don't have a clear idea of how much i want to spend... i mean... just to record my own stuff... maybe less than $ 1,000 ???
:P :)
So 4+ tracks for under $1k. Well you can get an alesis multimix firewire 8 for $165. This is a mixing desk with preamps, AD/DA convertion and an interface built in. It starts with 4 mic preamps, but you can upgrade this to 8(I suggest 2 M-Audio DMP3s). I'm sure it comes with a Lite version of some popular software, but I'd recommend Cockos Reaper for $50.
For mics it completely depends on what you need it for. If you want to record drums, you will need 2 overheads, snare and kick mics. I'd recommend some naiants(talk to Jon, aka mshilarious, the owner about which) for overheads and probably snare too (I like condensers on snare) and something like a shure beta 52 for kick.
For monitors, there are a few options. I'd recommend Alesis m1 mk2s, Behringer B2031A Truths, or Wharfedale DP8.2A. All around $300 for a pair.
There's a lot to acoustics but i'd recommend you make your own absorption panels from rigid fiberglass. For control room you need to treat the corners with at least 4" and side/ceiling first reflection points and the back wall with at least 2". Read Ethan Winer's acoustics FAQ for a detailed explanation.
