Walt-Dogg
So I've got this incessant buzzing noise coming from my amp.
Guitar (Ampeg ADA6 with single blade pick-up in) > Ibanez TS9-DX > Marshall Mosfet Lead 100 > Soldano 4x12 w/ Vintage 30's.
I'm guessing it's just mixing the pedal with the amps own gain channel. But that means the only cure is rolling back the gain on the amp with I really dont want to do because then it's like the pedal isn't even there.
I don't want another pedal, I dont need another amp, I'm looking at solutions like a possible bad component in the amp (provided it's not just the gain of the amp and the pedal not mixing well), bad cable, bad ground (which I'm inclined to believe) in the amp or guitar. Or a better way to mix the amp's gain with the pedal.
For tonal reference, this is the sound I'm going for:
myspace.com/annihilationtime
I'm using the same pedal and guitar, getting the same amp soon, but I can see it still being a problem even with a different amp.
So help?
So help?
