Techno-Archeology: TimeLine Product Documentation and Upkeep
  • Thread starter Thread starter brainditch
One of my LYNX II is loosing it's settings if its rebooted.
Battery is fine so its something else...RAM??
Does anyone have the schematics for these.
I only have the manual.
Cheers/
May I just add to the end of this thread, my sincere thanks to everyone involved ! I just strolled in and got precisely what I wanted for free .. as my son would say "You guys are awesome .."
Edit:- I may be able to add a tiny little piece of information that after huge amounts of searching I could not find here.
On the Lynx 1 FILM module, I could not find a pinout. notes for the Eprom but not the pins. What I needed to do was to attach an encoder to a shaft and read the timecode from there.
It will not surprise you to learn that the pins are the same on the Lynx2 film card as the Lynx1 dedicated film box.
So in my application of adding an encoder to a film playback machine.
On the 50 pin Transport plug
Pin 1 :- GND
Pin 16 :- BiPhase A
Pin 17 :- BiPhase B
Almost no encoders (certainly those fitted to older film equipment) have a consumption of less than 50ma so it's important to rig up an external power supply ..
5(B). Service Bulletin #SB 93-001, Date: ?
Title: MIDI Time Code Master
Requirement Level: Optional
Brief Description: Unknown contents, however this document is known to exist (a photo of what appears to be original issuance paperwork appeared on a Reverb-dot-com sale posting completed on 12/23/2017).
Anyone with a copy of this document is asked to please take some pictures of it, or scan it to PDF if possible, so that the contents can be preserved for posterity.
A big thank you for all this documentation! I have a couple of things to add. I've attached the Micro Lynx Service Bulletin No. 93-001 MIDI Time Code Master and a Prom Installation Guide for the Micro Lynx.
Hey All,
Thanks for these very informative threads. Miroslav, if you don't mind, can you clarify which protocol you choose on your MicroLynx for your MX80? The only one that comes up on my transport menu is the MX70, on version 1.34.
I used the information re: cables to construct my own Microlynx to MX80 (OTARI Type A) cable, and it beeps out fine!
Of course now , I too am having the same problems as zhou, I get No Transport Available message, and I'm investigating a PROM burner for possible solution to this,
...and issues with another Otari remote, the CB-120B Autolocator. The remote display powers up and counts tape position properly when the reels are spun by hand, but locks up all transport commands so that the machine and the CB-124 transport buttons have no effect on the machine. Another PROM issue?
These old units are melting before our eyes... Thankfully my MX80 and CB-124 run on their own happily, however the allure of also having my MTR-10 join the band with ProTools and the MicroLynx is a distant dream for now :-)
Just thought I'd ask the pros in this thread if they have any sage advice. Thanks for reading!
A bit off topic, but do you happen to have a manual for the CB-120 you can share?
Oh, I hope someone out there does. I also have the autolocator but have never really been able to figure it out how to make it do anything useful. The Otari came with a nice set of manuals, but only for the multitrack itself, not the accessories.
I will definitely post it if I ever find one.
Just wanted to say — just picked up a micro lynx on the way with no power supply or cables, and thank you all for contributing. This is going to be super helpful. Yay internet!
good luck! I'm in the process of setting mine up with a JH24. So far, it's not exactly fun.
Has anyone successfully setup a Microlynx with the JH24? (protools/MTC being master)? I wasn't sure if there was anything I wasn't aware of on setup, especially on the jh24 side. So far I have the tape machine (on the machine itself) set to EXT, and on the Autolocator set to VAR. I've also done the auto locator mod, and the short mod (on the actual Microlynx system box transport section). I was in the process of setting up the JH24 to have Smpte striped to it (via TCG on the ML) and the tape machine just started rewinding and smashing the tape everywhere until I could get it to stop. Turned it back on and now JH24 is dead (no play, record, shields etc.- will only FF/RW). Clearly something happened to it via the ML. Once I figure out what went wrong id prefer it not to happen again... :). Any help is appreciated. Also note, burned new Eproms to the lastest (from here ) firmware for keyboard, CPU and transports. Also my Microlynx has fresh batteries on both and I modded it to a fresh modern LCD screen.
1A. The Observation Report I generated from a Lynx-2 to Alesis AI-2 cable (71384). Although a rather wordy document (at 13 pages), it covers in exhaustive detail the cable's construction, with added speculations regarding signal descriptions vs. twisted conductor pairings, and includes the (first and only) available schemo of the cable wiring:
TACH IN sort of doesn't make sense, given the presumed nature of the Lynx-2 to AI-2 relationship, unless there's something I didn't catch. A Tach signal is usually presented to a synchronizer as a means of describing how fast the attached deck's Transport is moving, particularly when the deck is moving in either Fast Forward or Rewind Modes, and the speed of the passing Timecode is potentially not going to be read accurately. This signal should not be coming from a Lynx-2, as the AI-2 (and its controlled ADATS) are considered the only Transport involved here,
I suspect the tach signal is going from the (micro)lynx to the AI-2, and is used as a frame reference to keep the word clock and the timecode at consistent phase with each other. This seems to sync(!) with the AI-2 documentation:
5.11A External Word Clock Reference
The AI-2 sample rate and time code are derived from an external word clock present at the W/C in connector and one of the three" secondary" frame reference signals described below, Lynx synchronizer, video or internal.
Word clock by itself does not contain frame information so the AI-2 will derive its frame rate reference by bringing its time code frames into alignment with one of the secondary references. For this reason three word clock reference selections are provided.
When operating with an external word clock reference, IT IS ESSENTIAL THAT THE EXTERNAL WORD CLOCK AND FRAME REFERENCE ARE SYNCHRONIZED TO EACH OTHER. If this is not the case, then program material recorded on the ADAT will drift relative to time code. For this reason, THE W/C IN CONNECTOR SHOULD BE USED WITH CAUTION.
5.11B Lynx Reference
The AI-2 sample rate and time code are referenced to a special frame reference signal, provided for the AI-2 by the synchronizer, at the LYNX-2/MICRO LYNX connector. This signal ensures that the AI-2 will always be correctly synchronized with the frame reference of the synchronizer system. If the synchronizer system reference is changed, the AI-2 will automatically lock to and run at the new reference rate.
all my studio stuff is packed up right now, but it includes a microlynx and an AI-2. I have been wondering for years how to keep word clock and timecode from being plesiochronous. I'm wondering how "sample accurate" a tape deck or hard disc recorder can be when driven externally. also trying to figure out where to get a honda connector for my MX5050 so I can make a cable for it...
Do you have a BIII version MX-5050? Is this the connector you’re referencing? The PARALLEL I/O connector? Isn’t that just a 37-pin DSUB connector?
