leavings
Member
I understand the concept of the auxiliary buses, but I can't figure out how to use them correctly. Here's what I know:
1) I have the output set to the correct device (for example: '3,4 Direct Pro Q10').
2) I know I have to have the Send Enable turned on in the console for each track I want the auxiliary effect applied to.
After that I'm clueless. Whenever I add an effect it sounds different from when I place the effect directly on the track. I don't understand if I need to put the aux. send level up on the track, or the send and return levels up in the bus. Same goes for the send and return balance. And what the hell is that Pre/Post fader enable button???
If you can answer any or all of these questions I will love you long time.
Thanks,
Peter
Thanks,
Peter
